cabwav
Jun 27, 2016Tutor
Replacing disks on NVX with previously used 3Tb model fails
Hello I have a RNDX4210 NVX Business Edition running RAIDiator 4.2.27. Some time ago I replaced all four 3Tb disks (Seagate ST33000651AS) with 4Tb models (Seagate ST4000VN000). Because I plan to ...
- Jun 27, 2016
cabwav wrote:
Thank you for the quick reply! AFAIK a factory reset means that all data that was on the drives is lost, is that correct?
Yes
cabwav wrote:
is there any way to do a FR without losing the data?
No it isn't. It is perhaps possible to force the RAID array to mount, but there likely would be file system corruption.
cabwav
Jun 27, 2016Tutor
Hi StephenB
Thank you for the quick reply! AFAIK a factory reset means that all data that was on the drives is lost, is that correct? I made a backup so it's no big deal, but it would be nice if I could still access the data on the 3Tb disks. Assuming that the disk information is stored somewhere in the OS, is there any way to do a FR without losing the data? I read somewhere that there was a 'SSH method' but I can't find where that was.
Thanks again,
cabwav
Jun 27, 2016Guru - Experienced User
Yes
- cabwavJun 28, 2016Tutor
Hi StephenB
Thank you
cabwav
