BPreusing
Nov 07, 2019Aspirant
Replacing ReadyNAS RN31400 Chassis
Hello, my 4 years old RN31400 contains 4 harddisks and starts to be very loud sometimes, possibly the fan. Today I upgraded the firmware to 6.10.2 So I decided to replace the chassis with a new on...
- Nov 08, 2019
BPreusing wrote:
Your hint to RMA is welcome, but now I have ordered a RN424. If the noise persists, I have to determine, which disk it is and replace it and the old chassis will become a backup device, replacing my much older RNDU2120.
I do get the plan. But if turns out to be the chassis, you could still do an RMA of the old one (and use the RMA as the backup). Just a thought.
BPreusing
Nov 08, 2019Aspirant
Thanks again.
The noise (fast, ~120bpm: tack,tack,tack,...) is only sometimes, very low and started about 3 or 4 days ago.
I have attached a system screenshot where you can see my disks, too. All 4 disks are WDC and about the same age.
Dust is very likely. I will see, when I open it tomorrow.
Nov 08, 2019Guru - Experienced User
- BPreusingNov 14, 2019Aspirant
Thanks for the helpful community support.
It turned out to be dust. I cleaned it with a strong vacuum cleaner, and now it is silent again.
I will replace it with a RN424 this weekend and use the RN314 as backup device.
