Anselmino's avatar
Anselmino
Restart a ReadyNAS NV+ RND4000 after many years of downtime
Hi folks, after many years of downtime I try to reactivate my NV+ (RND4000) NAS server for nostalgic reasons. I took it out of service after some big trouble with the firmware of the seagate Barrac...
  • StephenB's avatar
    Aug 04, 2018
    4.1.13 should work with 2 TB disks, but still you should upgrade to the current firmware, which is 4.1.16.   You can try the check-for-updates feature in the web ui, or you can download it manually from here: https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc
    If you do a manual install, then you need to unzip the download and install the binary image.  Installing the zip file won't work.
    Documentation for your NAS is found here: https://www.netgear.com/support/product/RND4000v1_(ReadyNAS_NV_plus_v1).aspx
    Although you didn't ask about disks, I do want to point out that the hardware compatability list for your NAS hasn't been updated in many years now.  The best option is to use a NAS-purposed drive (the 2 TB WDC Red or Seagate Ironwolf).  Enterprise-class drives are overkill, your NAS isn't fast enough to take advantage of them.  I don't recommend using desktop-class drives in any NAS.
    Also, if you are using the NAS with Windows 10...  Microsoft is deprecating the SMB 1.0 client that is needed to access the NAS through file explorer.  You can manually enable it - try entering "turn windows features on or off" in the windows search bar.
    My own NV+ is still in service btw - though I am only using it as a secondary backup.  I plan to continue to run it until it fails, but I won't invest more money in it.  It's been very reliable for me, but it's capacity and performance isn't enough anymore.
ProSupport for Business
