Anselmino
Aug 04, 2018Aspirant
Restart a ReadyNAS NV+ RND4000 after many years of downtime
Hi folks,
after many years of downtime I try to reactivate my NV+ (RND4000) NAS server for nostalgic reasons. I took it out of service after some big trouble with the firmware of the seagate Barrac...
- Aug 04, 2018
4.1.13 should work with 2 TB disks, but still you should upgrade to the current firmware, which is 4.1.16. You can try the check-for-updates feature in the web ui, or you can download it manually from here: https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc
If you do a manual install, then you need to unzip the download and install the binary image. Installing the zip file won't work.
Documentation for your NAS is found here: https://www.netgear.com/support/product/RND4000v1_(ReadyNAS_NV_plus_v1).aspx
Although you didn't ask about disks, I do want to point out that the hardware compatability list for your NAS hasn't been updated in many years now. The best option is to use a NAS-purposed drive (the 2 TB WDC Red or Seagate Ironwolf). Enterprise-class drives are overkill, your NAS isn't fast enough to take advantage of them. I don't recommend using desktop-class drives in any NAS.
Also, if you are using the NAS with Windows 10... Microsoft is deprecating the SMB 1.0 client that is needed to access the NAS through file explorer. You can manually enable it - try entering "turn windows features on or off" in the windows search bar.
My own NV+ is still in service btw - though I am only using it as a secondary backup. I plan to continue to run it until it fails, but I won't invest more money in it. It's been very reliable for me, but it's capacity and performance isn't enough anymore.
Anselmino
Thank you very much for the quick answer. My NV+ is not connected to the internet and just runs as a local storage for an old desktop with Win XP.
I told the NV to do a reboot and check disks at next boot. Unfortunately it comes up with a "Found bad disks" message without saying which one is bad. Yesterday all of them were still fully ok. The boot sequence doesn't finish. May I take out the disks one by one in this state?
If the NV+ will not boot, I can't test the firmware update. It also doesn't shut down when pressing the power button for five seconds. I will need to force it down most likely, because it is also not accessible via RAIDar so far.
Aug 04, 2018Guru - Experienced User
Yes. Forcibly power down and then you can test the disks one-by-one n a windows PC using vendor tools (seatools for seagate, lifeguard for western digital). You can connect the disks using SATA or a USB adapter/dock. I doubt that the vendor tools run on XP anymore.
You can also start over, doing a factory reset with only one disk in place. If that works, upgrade the firmware. Then examine the SMART stats for the disk, and make sure it is actually healthy. If it fails, try again with another disk.
Then hot-insert the second disk, and wait for it to resync. If that succeeds, re-examine the SMART stats for both drives. Repeat this for the remaining disks.
