xuco80
Aug 26, 2018Tutor
Restore default factory
Hello! I want to reset to factory my ReadyNas 104, but I don´t want loss my data. I have 3 disk, 9TB in JOBD.
If I disconnect the three disks and do a factory reset, when I reconnect them I wil...
mdgm-ntgr
Aug 26, 2018NETGEAR Employee Retired
The whole purpose of a factory reset is to wipe all data, settings, everything. Trying to do a factory reset with the disks removed will achieve nothing.
Why do you want to reset things back to factory default?
- xuco80Aug 26, 2018Tutor
it does not show the applications and if I try to install one manually it gives me an error. There is a problem with the software.
- mdgm-ntgrAug 26, 2018NETGEAR Employee Retired
Have you tried a different web browser?
Have you downloaded the logs zip and checked the logs for clues (you can send the logs in if you like, see the Sending Logs link in my sig)?- xuco80Aug 27, 2018Tutor
Yes, mozilla, chrome and iexplorer...
I erased the logs :(
I have read about reinstall OS
https://kb.netgear.com/22891/How-do-I-access-the-boot-menu-on-my-ReadyNAS-104-204-214-or-314
Can this solve my problems without losing the data?
