xuco80
Aug 26, 2018Tutor
Restore default factory
Hello! I want to reset to factory my ReadyNas 104, but I don´t want loss my data. I have 3 disk, 9TB in JOBD.
If I disconnect the three disks and do a factory reset, when I reconnect them I wil...
Marc_V
Sep 02, 2018NETGEAR Employee Retired
Hi xuco80
Welcome to the Community!
What Apps are you trying to install? IS your NAS already on BETA firmware? 3rd Party Apps might not have support for the latest Beta or official version that might be also the cause for the app not to install/work.
You may want to check your logs under systemd-journal.log and go to the timeline where you tried to install the App. Try to check volume.log as well and see if your OS(md0) is full.
Regards
