xuco80
Aug 26, 2018Tutor
Restore default factory
Hello! I want to reset to factory my ReadyNas 104, but I don´t want loss my data. I have 3 disk, 9TB in JOBD.
If I disconnect the three disks and do a factory reset, when I reconnect them I wil...
Marc_V
Sep 02, 2018NETGEAR Employee Retired
Hi xuco80
Welcome to the Community!
What Apps are you trying to install? IS your NAS already on BETA firmware? 3rd Party Apps might not have support for the latest Beta or official version that might be also the cause for the app not to install/work.
You may want to check your logs under systemd-journal.log and go to the timeline where you tried to install the App. Try to check volume.log as well and see if your OS(md0) is full.
Regards
xuco80
Sep 02, 2018Tutor
Hello Marc_VMarc_V
Thank you very much for answering.
I really want to install plex but when I go to the section of available applications, they appear blank and I can not install any other. I can not install any.
The log I sent it to mdgm-ntgr
The current firmware is 6.9.3 Stable version
- Marc_VSep 02, 2018NETGEAR Employee Retired
Hi xuco80
Unfortunately mdgm is not with NETGEAR anymore, It would be good if he had taken a look on your logs.
I would advise contacting NETGEAR Support so experts can get this escalated and fixed.
Have you tried installing other apps from apps.readynas.com?
Regards
