xuco80
Aug 26, 2018Tutor
Restore default factory
Hello! I want to reset to factory my ReadyNas 104, but I don´t want loss my data. I have 3 disk, 9TB in JOBD.
If I disconnect the three disks and do a factory reset, when I reconnect them I wil...
xuco80
Sep 02, 2018Tutor
Hello Marc_VMarc_V
Thank you very much for answering.
I really want to install plex but when I go to the section of available applications, they appear blank and I can not install any other. I can not install any.
The log I sent it to mdgm-ntgr
The current firmware is 6.9.3 Stable version
Marc_V
Sep 02, 2018NETGEAR Employee Retired
Hi xuco80
Unfortunately mdgm is not with NETGEAR anymore, It would be good if he had taken a look on your logs.
I would advise contacting NETGEAR Support so experts can get this escalated and fixed.
Have you tried installing other apps from apps.readynas.com?
Regards
