xuco80
Aug 26, 2018Tutor
Restore default factory
Hello! I want to reset to factory my ReadyNas 104, but I don´t want loss my data. I have 3 disk, 9TB in JOBD.
If I disconnect the three disks and do a factory reset, when I reconnect them I wil...
Marc_V
Sep 02, 2018NETGEAR Employee Retired
Hi xuco80
Unfortunately mdgm is not with NETGEAR anymore, It would be good if he had taken a look on your logs.
I would advise contacting NETGEAR Support so experts can get this escalated and fixed.
Have you tried installing other apps from apps.readynas.com?
Regards
