NullNilNaN
Jan 05, 2017Aspirant
Restore disk geometry after OS reinstall
Hello, I have a RN104 which was shutdown for a while (maybe 6 months), I have tried to power it on but the HTTP service was down and the NFS credentials were gone. I tried an OS reinstall accord...
- Retired_MemberJan 06, 2017
Hi,
The HDD#4 S/N ****1338 is dead and generating a lot of errors. You should shut down from the GUI, remove this HDD (double check the S/N) and try boot up the NAS again. If the data volume is then accessible, you should insert a replacement HDD asap to resync the volume to a redundant state.
Serial: *****1338 ATA Error Count: 2297 Current Pending Sector Count: 17 Uncorrectable Sector Count: 263
[Fri Jan 6 08:44:57 2017] ata1.00: status: { DRDY ERR } [Fri Jan 6 08:44:57 2017] ata1.00: error: { UNC } [Fri Jan 6 08:44:57 2017] ata1.00: configured for UDMA/133 [Fri Jan 6 08:44:57 2017] sd 0:0:0:0: [sda] tag#24 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE [Fri Jan 6 08:44:57 2017] sd 0:0:0:0: [sda] tag#24 Sense Key : Medium Error [current] [descriptor] [Fri Jan 6 08:44:57 2017] sd 0:0:0:0: [sda] tag#24 Add. Sense: Unrecovered read error - auto reallocate failed [Fri Jan 6 08:44:57 2017] sd 0:0:0:0: [sda] tag#24 CDB: Read(10) 28 00 00 05 a6 e8 00 00 08 00 [Fri Jan 6 08:44:57 2017] blk_update_request: I/O error, dev sda, sector 370408You should also see warnings about this HDD in the logs section of the GUI:
[16/11/08 11:02:09 CET] notice:disk:LOGMSG_SMART_UNCORR_ERR_WARN Detected high uncorrectable error count: [263] on disk 4 (Internal) [WDC WD20EZRX-00D8PB0, *******1138]. This condition often indicates an impending failure. Please be prepared to replace this disk to maintain data redundancy. [16/11/08 11:03:27 CET] notice:disk:LOGMSG_SMART_ATA_ERR_30DAYS_WARN Detected increasing ATA error count: [1890] on disk 4 (Internal) [WDC WD20EZRX-00D8PB0, *******1138] 1 times in the past 30 days. This condition often indicates an impending failure. Please be prepared to replace this disk to maintain data redundancy. <snip> [16/11/22 15:19:12 CET] notice:disk:LOGMSG_SMART_ATA_ERR_30DAYS_WARN Detected increasing ATA error count: [2077] on disk 4 (Internal) [WDC WD20EZRX-00D8PB0, *******1138] 7 times in the past 30 days. This condition often indicates an impending failure. Please be prepared to replace this disk to maintain data redundancy. [16/11/22 15:36:36 CET] notice:disk:LOGMSG_SMART_ATA_ERR_30DAYS_WARN Detected increasing ATA error count: [2101] on disk 4 (Internal) [WDC WD20EZRX-00D8PB0, *******1138] 8 times in the past 30 days. This condition often indicates an impending failure. Please be prepared to replace this disk to maintain data redundancy. [16/11/22 15:40:11 CET] notice:disk:LOGMSG_SMART_ATA_ERR_30DAYS_WARN Detected increasing ATA error count: [2113] on disk 4 (Internal) [WDC WD20EZRX-00D8PB0, *******1138] 9 times in the past 30 days. This condition often indicates an impending failure. Please be prepared to replace this disk to maintain data redundancy.
NullNilNaN
I'm pretty sure it wasn't encrypted.
I've followed the procedure to send you my logs.
Thanks / Regards.
Retired_Member
Jan 06, 2017Hi,
- Jul 15, 2018Retired_Member
