edalquist's avatar
edalquist
Apprentice
Feb 18, 2017
Restrict NFS to entire subnet?
I'm using both network ports on my RN314. One is in on the normal LAN. The other is physically seperate and only connected to the secondary ports (and secondary virtual ports) on a bunch of machines/...
  • edalquist's avatar
    Feb 18, 2017
    And in writing this I thought "I wonder what would happen if I put a subnet mask in the IP field" and low and behold "192.168.200.0/24" works just as expected.
    Could I ask that it be documented in the UI in the next rev?
    Thanks!
ProSupport for Business
