aks-2
Jan 16, 2019Apprentice
Resync after power failure
I had a power failure yesterday, and my ReadyNAS NV+ v2 had no backup power source (UPS), so it went down and remained off. There were no users of the unit at the time, not for many hours in fact, bu...
- Jan 17, 2019
aks-2 wrote:
There were no users of the unit at the time, not for many hours in fact, but once I powered it up, it started a resync. Everything looks good.
What would be a good way to verify that I have not lost or corrupted files, or should I just reset everything back to defaults and restore a backup now?
I don't own a v2 NAS. But I believe the system is designed to do a resync whenever it detects an unclean shutdown - which it would do in this case.
It seems pretty unlikely that there would have been cached writes, given that no one had been using the NAS for hours. The volume mounted normally, which is also a good sign. So I think the odds of file corruption is low.
If you are concerned, then perhaps use a file verification tool to compare the NAS files against your backup. If something doesn't compare, then check the file dates, and see if it was updated after the backup was run. That would be less disruptive than doing a factory reset.
Jan 17, 2019Guru - Experienced User
aks-2
Jan 17, 2019Apprentice
Thanks, I will do a file comparison as suggested and report back - it will take a few days I suspect.
- aks-2Feb 22, 2019Apprentice
OK, for my own sanity, I did a full file comparison, the only chenges were related to Excel spreadsheets that update internal 'last accessed' data but keep file date/time unmodified.
I also purchased a CyberPower UPS now, it alerts my NV+ v2 whenever the power is lost, allowing time for it to shutdown safely if necessary :)!
