Sunfox1
May 08, 2023Aspirant
Revitalizing ReadyNAS Pro 6
I’ve been running a ReadyNAS Pro 6 since early 2012, using an X-RAID2 array of 3TB hard drives that went from (I believe) 4 x 3TB now to 6 x 3TB. I’ve had to replace a bunch of drives over the year...
Sandshark
May 08, 2023Sensei
If it's really a Pro6 (part number ends with -200), then no need for a processor upgrade. If it's really a ProBE or Pro Pioneer (-100), then a processor upgrade will have benefits. But if it is a -100, make sure you update the BIOS before conversion. AFAIK, all Pro6 units have the latest, but you should check.
Sunfox1
Thanks. It is a Pro 6 - BIOS shows as "07/26/2010 FLAME6-MB V2.0" and in boot_info it shows "model: ReadyNAS Pro 6"... and looking up the old bill of sale, part number is -200. Is v2.0 the most current BIOS?
I've ordered a 4gb kit (2x2gb) since I didn't want to get into the can of worms that is 4gb modules. I've already swapped the PSU a few years ago, but I might now consider a fan replacement with a Noctua or something - although from a quick look I understand the pinout would need to be adjusted?
- SandsharkMay 09, 2023Sensei
Putting in the Noctua fan is potential trouble, as it's stall speed is different than the stock fan. While the OS6 fan control on legacy NAS has been fixed for a long while, changing out the stock fan for one with different specs can cause problems. Definitely don't do it until you see if you need it more quiet than with OS6 on the "Quiet" setting.
