steveoelliott
Mar 24, 2017Luminary
RMA ReadyNAS Pro 6
Hi all, I've just RMAed my aging ReadyNAS Pro 6 due to PSU failure and as they are inbuilt there was no option to replace the chassis. I do know you can purchase and retrofit another PSU as descr...
mdgm-ntgr
Mar 27, 2017NETGEAR Employee Retired
If you have concerns with the condition of the replacement unit you can take high-res photos of the unit and include those in your report.
Your 5 year limited hardware warranty still has some months left (you can see the exact date logging into the support portal).
It's a good idea to put a scratch disk (must not be from your array) in the replacement unit, update the firmware to what you were running on the old unit, verify the firmware update is successful, power down, remove the scratch disk and migrate your disks across.
