vincefr
Apr 29, 2015Aspirant
RN 104 disk size upgrade does not upgrade volume size
Hello, here are the details : - started a RN104 with one 4Tb hard disk drive, volume size was OK to 4 Tb - added a 5Tb HDD, volume size remains 4 Tb, OK as it was depending on the smaller disk. ...
mdgm-ntgr
Apr 29, 2015NETGEAR Employee Retired
Perhaps try a reboot?
If it still does not expand can you send me your logs (see the Sending Logs link in my sig)?
