MMcD3v1
Jul 01, 2017Tutor
RN 214 OS 6.7.5. DNLA duplicated songs listed on receiver
On my 214 running OS6.7.5 I'm seeing duplicated (actually 3) listings of every song in my music library on my Yamaha receiver running the most recent version of its firmware. The song/files are not du...
aks
Jul 12, 2017Virtuoso
First disable ReadyDLNA in the web UI.
At the ssh terminal, launch ReadyDLNA manually:
/sbin/minidlnad.bin -v -d -R
I'm not at my vm now so can't check exactly, but the options I used are:
-v verbose
-d debug
-R rescan
-v verbose
-d debug
-R rescan
Skywalker
Jul 13, 2017NETGEAR Expert
You may be able to get an idea by looking at the database entries. Try this from the ReadyNAS command line:
# sqlite3 /apps/.readydlna/files.db 'select path from details where mime like "audio/%"'
- MMcD3v1Jul 13, 2017Tutor
All - made progress. sorry for my delay. my job has occupied me.
With your help I was able to find dulpicates of the actual songs. Some how inside one of the [share]/ itunes/music folders .i.e, {share}/itunes/music/various - itunes/music was duplicated inside it. AND within that it was dupicated again.
Now I'm still chasing a few duplicates but most of them have been deleted and the DNLA clients have clean list (there are a few transient duplicates).
I confirmed from backups that somehow it happend when the data was restored from the NV+ backup on the external USB drive that was used. The USB drive was clean but in the upload this weirdness must have occured.
- aksJul 14, 2017Virtuoso
This can happen if you move/rename folders and then make an incremental backup - the original files stay in tact, and new (renamed) get added. After a restore, you have multiple copies.
This experience highlights the importance of reducing the number of files for testing purposes ;).
Good news it's sorted and not a real scary problem with the RN...
