Alex3111
Jan 11, 2015Aspirant
RN 314 os 6.2.2 and Plex (not updating metadata) (SOLVED)
Hello Plex guys, I just added a ReadyNAS 314 4x3TB along my already working ReadyNAS NV+ V2. The ReadyNAS NV+ V2 is running RAIDiator 5.3.11, it's an ARM v5 running Plex Server app for ARM 5.x...
Alex3111
nsne wrote: There are some settings in the newer Plex versions that you might have to mess with. When upgrading from an Ultra 4 to a 314, I was seeing unexpected behavior with Plex until I made these adjustments:
In the Plex Web UI, go to Settings > Server > Agents. You'll see several options for different media. Here you should just make sure that, say, "The Movie Database" is checked and at the top of the list where applicable (sometimes only "Local Media Assets" is ticked or at the top of the list). Then run a Force Refresh under each library, not just an update. That should work.
Also: It *is* weird that you're only seeing 2.3.3 under Settings > General > Version. I'm not sure how to account for that.
Thanks, but nope... I have the same 4 movies on a /Media/Movies/Test folder on both the NV+ and the 314, both running the same v0.9.11.7.803-87d0708, both connected to the same switch, router, etc., running the same IP subnet mask, gateway, the only difference is the 10.1.1.1 (NAS 314) to 10.1.1.2 (NAS NV+). Of course both Plex find the movies, and add them to the list, but the NV+ presents them nice and pretty, were the 314 only shows minutes into the movies as their posters. I did in fact disabled the Local Movie Assets, and moved them down the list, just in case.. and nothing.
This is driving me nuts! Been at it for several days now...
