aequus
Oct 25, 2017Aspirant
RN 516 - Remove inactive volumes to use the disk #4 – ghost volume
My device is running latest firmware 6.8.1 and has one raid 5 set of 6x6tb disk as data. Now the volume page shows disk 4 as a additional raid5 named data-1. On the message line appears “Remove inact...
- Oct 30, 2017
Yes, SDD (drive 4) is not a part ot MD126 (the second layer in your volume). Either the expansion did not go as it should when you added drive 4, or the NAS has "lost" that partition. But now it looks like it has found the lost partition and declared it to be a separate incomplete volume.
You may want to wait for mdgm-ntgr or one of the other Netgear mods to concur, but it looks to me like that's exactly why they changed the OS to be more aggressive in looking for lost volumes and that deleting it will do the trick. Whether it will then re-sync and add the lost space into the volume is another thing. You may need to remove the drive, delete the partitions, and let it start from there. But that would be far less work that a factory default and restore.
aequus
Oct 30, 2017Aspirant
here is the output of lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 5.5T 0 disk
├─sda1 8:1 0 4G 0 part
│ └─md0 9:0 0 4G 0 raid1 /
├─sda2 8:2 0 512M 0 part
│ └─md1 9:1 0 2G 0 raid6 [SWAP]
├─sda3 8:3 0 3.6T 0 part
│ └─md127 9:127 0 18.2T 0 raid5 /data
└─sda4 8:4 0 1.8T 0 part
└─md126 9:126 0 7.3T 0 raid5
sdb 8:16 0 5.5T 0 disk
├─sdb1 8:17 0 4G 0 part
├─sdb2 8:18 0 512M 0 part
├─sdb3 8:19 0 3.6T 0 part
└─sdb4 8:20 0 1.8T 0 part
sdc 8:32 0 5.5T 0 disk
├─sdc1 8:33 0 4G 0 part
├─sdc2 8:34 0 512M 0 part
├─sdc3 8:35 0 3.6T 0 part
└─sdc4 8:36 0 1.8T 0 part
sdd 8:48 0 5.5T 0 disk
├─sdd1 8:49 0 4G 0 part
├─sdd2 8:50 0 512M 0 part
├─sdd3 8:51 0 3.6T 0 part
└─sdd4 8:52 0 1.8T 0 part
sde 8:64 0 5.5T 0 disk
├─sde1 8:65 0 4G 0 part
├─sde2 8:66 0 512M 0 part
├─sde3 8:67 0 3.6T 0 part
└─sde4 8:68 0 1.8T 0 part
sdf 8:80 0 5.5T 0 disk
├─sdf1 8:81 0 4G 0 part
├─sdf2 8:82 0 512M 0 part
├─sdf3 8:83 0 3.6T 0 part
└─sdf4 8:84 0 1.8T 0 part
Sandshark
Oct 30, 2017Sensei
