teho59
Jul 20, 2018Tutor
RN 516 startup - loop at welcome
I am trying to start my NAS and it shows the first text "Netgear storage welcome", then the OK button with the arrow ring shows up. Half a second everyting disappers and after 2-3 second it repeats. ...
- Aug 10, 2018
An update:
I talked to support on the phone that guided me through a couple of things to try.
I tried to boot the NAS when holding the reset-button pressed without luck. This should lead to the boot menu. Then a USB-stick was created and inserted to the NAS. The NAS should now boot from the USB-stick but that did not happen. Nothing helped and the conclusion is that there is something wrong with the case. I have tried to boot without the disks and that made no difference either.
I will get a replacement. The support guy was patient and did a good job to guide me. Excellent support!
Marc_V
Jul 22, 2018NETGEAR Employee Retired
Hi teho59
Welcome to the Community!
What firmware are you running? Have you tried checking with RAIDar? It should show you the status of the NAS when booting.
You can download RAIDar here.
Regards
- teho59Jul 22, 2018Tutor
Hi,
I am unable to see the firmware, it "restarts" after 2-3 seconds. See the videofile attached. There you see the two repeats but it is going on and on.
I did an firware update about 6-8 weeks ago if I remember correct. I think I am on the last or second last version.
Link to videofile, was not able to insert in this reply: http://www.hopso.no/IMG_0364.MOV
- mdgm-ntgrJul 22, 2018NETGEAR Employee Retired
Are you the original purchaser of the unit from an authorised reseller and was it purchased less than 5 years ago?
- teho59Jul 23, 2018Tutor
"Are you the original purchaser of the unit from an authorised reseller and was it purchased less than 5 years ago?"
Why do you want to know that?
