gbeddow
Jul 05, 2020Luminary
rn-expand[2065]: Failed to get device type for /dev/md0: 25
I'm seeing this message in the logs every 2 minutes: rn-expand[2065]: Failed to get device type for /dev/md0: 25 I couldn't find much info on rn-expand, but it seems to relate to expanding volumes....
Marc_V
Jul 09, 2020NETGEAR Employee Retired
@ggbeddow
Just want to know as well if you are having issues with your NAS? This is to check if we need to investigate further.
The rn-expand queries each device on the ReadyNAS and that involves sda, sdb... and all md devices just like md0 which the message is about. rn-expand once it goes through the device lists, it tries to identify what type md0 is in this case the query cannot be completed successfully since it will not provide any info for a device type since it's a RAID device. Not really sure what should be the entry is but if you are not having any issues with the NAS I believe we can ignore those messages.
HTH
- gbeddowJul 09, 2020LuminaryNot having any issues with the NAS AFAIK other than these messages.Still, a message that clutters up the logs every 2 minutes seems worth fixing. Will this be addressed in a future ReadyNAS update, or at least through apt-get?
