Jophus
Oct 07, 2015Luminary
RN102 6.4.0 official firmware update not posted? Still 6.2.5
My RN102 informs me the 6.4.0 is available so I used OS6's update mechanism - which left it at 6.2.5. I did this twice with no "upgrade" performed.
I then looked to manually download the file ...
JennC
Oct 07, 2015NETGEAR Employee Retired
Hello Jophus,
Please use http://kb.netgear.com/app/answers/detail/a_id/29938 instead for downloading 6.4.0 firmware version.
- JmztaylorOct 07, 2015Aspirant
I am having a similiar problem. No matter what my OS doesn't upgrade. Whether I use the built in upgrade system or download that file manually and upload it never actually does the update.
- vandermerweOct 07, 2015Master
when you do the manual update, do you receive any error messages?
Did you try a different browser to do the update?
Did you unzip the downloaded file?
- Michael_H_QLDOct 07, 2015Aspirant
How can I manually do the update if I can't acces the admin page ?
Yes I have tried 3 browsers with the same result, it's the NAS end where the problem lies
Yes I unzipped the download file
I have also made a recovery USB stick but not had any success with that either ...
Update: Just maged to reboot the NAS this morning and got the admin page to load, have followed the manual process to Upload ReadyNASOS-6.4.0-arm.img and it's just finsihed the upload and I clicked to reboot ... hasn't done it yet but fingers crossed this takes and works.
- JophusOct 07, 2015Luminary
JennC wrote:Hello Jophus,
Thanks JennC. However Netgear are misleading users by stating a 6.4.0 update is available when the link clearly goes to 6.2.5. When will the correct Auto-notification update to 6.4.0 accurately link to the 6.4.0 update? Why notify of an update and link to an existing firmware version? Further - when will the official support site link to the correct firmware... on both the:
http://downloadcenter.netgear.com/en/product/RN10200#searchResults
and
http://support.netgear.com/product/RN10200
The "6.4.0" text links to a "6.2.5" file.
Come on guys... release it properly or don't release it at all!
- JophusOct 08, 2015Luminary
Notwithstanding the posting of incorrect files on the Netgear support website - my RN102 won't upgrade when manually fed the 6.4.0 arm binary image.... stays at 6.2.5. The upgrade appears to work, askeing me to reboot.... but in my Ultra 6 log showed and entry:
Wed Oct 7 2015 14:58:59 System: Firmware was upgraded to 6.4.0. Wed Oct 7 2015 14:58:59 System: ReadyNASOS background service started. Wed Oct 7 2015 14:55:16 System: The system is rebooting. The RN102 just reboots, shows "6.2.5" on the splash and then asks me to update to 6.4.0 again........
Thu Oct 8 2015 10:07:05
System: ReadyNASOS background service started. Thu Oct 8 2015 10:05:43 System: The system is rebooting. Thu Oct 8 2015 9:59:34 System: ReadyNASOS background service started. Thu Oct 8 2015 9:58:15 System: The system is rebooting. Thu Oct 8 2015 9:52:57 System: ReadyNASOS background service started. Thu Oct 8 2015 9:51:37 System: The system is rebooting. Thu Oct 8 2015 9:49:10 System: ReadyNASOS background service started. Thu Oct 8 2015 9:47:41 System: The system is rebooting. Thu Oct 8 2015 9:36:53 System: ReadyNASOS background service started. Wed Oct 7 2015 15:31:02 System: System is shutting down. Wed Oct 7 2015 15:18:44 System: ReadyNASOS background service started. Wed Oct 7 2015 15:17:21 System: The system is rebooting. Wed Oct 7 2015 15:09:00 System: ReadyNASOS background service started. Wed Oct 7 2015 15:07:37 System: The system is rebooting. I have "upgraded" 6 times now without moving from 6.2.5. What is happening?
- JennCOct 08, 2015NETGEAR Employee Retired
Hello Jophus,
When you click the 6.4.0 link at http://downloadcenter.netgear.com/en/product/RN10200#searchResults it downloads the zipped file and when you open it, it has 2 different files, the released notes and the IMG file which is the 6.4.0 firmware. I did this and was able to see the FW file.
- StephenBOct 08, 2015Guru - Experienced User
The log suggests you have the correct firmware image, but something else is wrong. A filling OS partition is one thing that can prevent updates (and likely there are others).
You might need to contact support.
There is also the cheap but painful way out - try a factory reset and then upgrade. The rebuild the NAS, restore data from backup, etc.
JennC- The support page for the RN102 was definitely wrong yesterday. The 6.4.0 link pointed to the 6.2.5 zip. That is fixed now.
- kohdeeOct 08, 2015NETGEAR Expert
Hi,
Sorry, we fixed the downloadcenter to use the 6.4.0 binary instead of the 6.2.5 binary for the 6.4.0 release to ARM boxes. It should be the 6.4.0 binary now for those trying. The release notes page for 6.4.0 always listed correctly the 6.4.0 arm build. http://kb.netgear.com/app/answers/detail/a_id/29938
http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNASOS-6.4.0-arm.zip
If your unit is not getting 6.4.0 update request automatically, check your network setttings (DNS, gateway) and confirm it has internet access.
If you're having another issue like where the ReadyNASOS seems to be restarting constantly, you might want to contact support or private message a link to your logs so I can just review what is going on. This could be caused by your browser caching the 6.2.5 interface instead of requesting the 6.4.0 interface. Sending old calls for data retrieval in the UI when they've been updated to a new version could be a cause for this. Thanks.
Hello kohdee. This stil hasn't worked for me on my RN102.
I used Chrome yesterday to both:
Auto-update via OS6 web interface AND
download and manually update via "Settings" using the image file INSIDE the zip file
Today I re-downloaded manually and tried again both:
In Chrome (auto and manual update), and
Edge (auto and manual update)
My box has now "updated" 10 times and I am still on 6.2.5 - and it still prompts me to download the update.....
This is not a good experience so far, both with the inconsistent posting of the update between webpage/system by Netgear and the fact that it just won't work.
I will just stay on 6.2.5 until Netgear sorts it out. Is there a way to disable the auto update notification?
