Jophus
Oct 07, 2015Luminary
RN102 6.4.0 official firmware update not posted? Still 6.2.5
My RN102 informs me the 6.4.0 is available so I used OS6's update mechanism - which left it at 6.2.5. I did this twice with no "upgrade" performed.
I then looked to manually download the file ...
JennC
Oct 07, 2015NETGEAR Employee Retired
Hello Jophus,
Please use http://kb.netgear.com/app/answers/detail/a_id/29938 instead for downloading 6.4.0 firmware version.
Jmztaylor
Oct 07, 2015Aspirant
I am having a similiar problem. No matter what my OS doesn't upgrade. Whether I use the built in upgrade system or download that file manually and upload it never actually does the update.
- vandermerweOct 07, 2015Master
when you do the manual update, do you receive any error messages?
Did you try a different browser to do the update?
Did you unzip the downloaded file?
- Michael_H_QLDOct 07, 2015Aspirant
How can I manually do the update if I can't acces the admin page ?
Yes I have tried 3 browsers with the same result, it's the NAS end where the problem lies
Yes I unzipped the download file
I have also made a recovery USB stick but not had any success with that either ...
Update: Just maged to reboot the NAS this morning and got the admin page to load, have followed the manual process to Upload ReadyNASOS-6.4.0-arm.img and it's just finsihed the upload and I clicked to reboot ... hasn't done it yet but fingers crossed this takes and works.
Yes a reboot is always worth a try.
I would not ever do a usb boot recovery unless you are specifically instructed by Netgear to do this.
It is always a last resort intervention when all other options have failed.
USB boot recovery can make things much worse.
- JmztaylorOct 07, 2015Aspirant
Yes to all except no error message. Just reboots like normal every single time. Even if I use the built in update system it never updates.
