SimonST's avatar
SimonST
RN102-6.7.5 fails on SFTP connection with client error 10054-connection reset by peer
I'm using the ReadyNAS as an SFTP server (Subsystem sftp internal-sftp) and I've been running 6.4.1 for 18 months without a hitch. Never had any problems...
I upgraded to 6.7.5 at the weekend and now client sftp apps are getting a 10054 error.
The RN system log shows no errors
Jul 31 10:56:16 FileServer sshd[3794]: SSH: Server;Ltype: Version;Remote: [IP]-9761;Protocol: 2.0;Client: WeOnlyDo
Jul 31 10:56:16 FileServer sshd[3794]: SSH: Server;Ltype: Kex;Remote: [IP]-9761;Enc: aes128-ctr;MAC: hmac-sha2 256;Comp: zlib@openssh.com [preauth]
Jul 31 10:56:16 FileServer sshd[3794]: SSH: Server;Ltype: Authname;Remote: [IP]-9761;Name: [user] [preauth]
Jul 31 10:56:17 FileServer sshd[3794]: Accepted password for [user] from [IP] port 9761 ssh2
I've tried the same clients on a backup RN102 which is still running 6.4.1 and it's fine on that so something has changed between 6.4.1 and 6.7.5
I looked at the release notes on the interim versions but didn't see anything related.
Can anyone help?
Thanks
  • StephenB's avatar
    You might need to reinstall the ssh cert on the clients.
    • SimonST's avatar
      SimonST
      Yes, SSH is fine and SFTP is fine with tools like filezilla.
      A customer is using a component from WeOnlyDo for SFTP which is the problem as they cannot make changes to the app.
ProSupport for Business
