a4ex
Oct 23, 2017Aspirant
RN102 6.8.1 DLNA issues
Hello,
I have lately been having problems with the DLNA. I use the RN to store all my videos and watch them through my Samsung TV USING DLNA. I think all started after upgrading to 6.8.1. My setup is the same for years and I notished the issue after the upgrade. Now when I’m watching a video it will stop and the TV will through an error message “check your network connection” rendering impossible to watch videos. I tried restarting my router but with no lack. I also tried viewing a video from my mobile device and it will freeze. I will try to upgrade to the latest fw and check if the problem persists. Can you point the location for logs related to DLNA? There might be something there regarding the disconnects.
Thx in advance
Thx in advance
- bedlam1Prodigy
Download your logs using "System: Logs: Download Logs" using the GUI or use Raidar then open the zip file and open "upnp-av.log" to look for clues.
- a4exAspirant
Hi, The main error log that is printed constantly is
Oct 18 00:34:46 big-show-nas minidlnad[2129]: process.c:91: warn: Exceeded max connections [50], not forking
and first occurrence is after upgrade to 6.8.1.
I could change
max_connections
in
/etc/minidlna.conf.local
but i cant understand why so many connections open.
- a4exAspirant
I performed a reboot on the RN and now it seems is fixed. I assume that the open connections are closed.
