brianjmc1
Oct 09, 2016Tutor
RN102 bricked
Was working fine, lost power now all I get is a blinking power light. No Gui or SSH. I can telnet to it. I have tried factory restore, reload OS through USB, nothing seems to be working. Just wonderi...
- Oct 09, 2016
Previously formatted disk(s) detected (Dirty Disks)
mdgm-ntgr
Oct 09, 2016NETGEAR Employee Retired
What do you see in RAIDar?
Being able to telnet in would suggest that you've run into an error during the early stages of the boot process.
brianjmc1
Oct 09, 2016Tutor
It shows everything, Model, name, serial, status, firmware(6.4.0), IP address, and mac address..
Thank you for the help!
- mdgm-ntgrOct 09, 2016NETGEAR Employee Retired
What's the status?
- brianjmc1Oct 09, 2016Tutor
"No disks detected" I pulled the disks, I have tried with them in too...
Do you get the same error with the disks installed?
If so, that would suggest either your disks are bad or there's a hardware issue with the chassis or external PSU.
