brianjmc1
Oct 09, 2016Tutor
RN102 bricked
Was working fine, lost power now all I get is a blinking power light. No Gui or SSH. I can telnet to it. I have tried factory restore, reload OS through USB, nothing seems to be working. Just wonderi...
- Oct 09, 2016
Previously formatted disk(s) detected (Dirty Disks)
brianjmc1
Oct 09, 2016Tutor
I will power down, power back up, then report back....
brianjmc1
Oct 09, 2016Tutor
- brianjmc1Oct 09, 2016Tutor
MDGM got me going again. Once I formatted the drives, the GUI came back....
Thanks for all the help!!!
- mdgm-ntgrOct 09, 2016NETGEAR Employee Retired
As you found after you clicked on the format button in RAIDar and confirm your choice the NAS wiped the disks and it has come up fine.
It's likely when the power failed the 4GB OS partition on the disks became out of sync. Anyway since you've wiped the disks there's no way to check now.
The OS is installed onto the disks.You can now mark a post containing the solution to your problem as the solution.
