LaszloFolgerts
Sep 19, 2018Aspirant
RN102 can't access web GUI some apps still accessible firmware reset?
Hi,
I can't acces the web GUI anymore on my RN102. Some other apps that I have installed are still working and accessible through their web GUI. The NAS is still visible on my network and I can...
- Sep 19, 2018
Clould do you please enable secure diagnostics mode and PM me 5 debug codes?
I can remote access to format OS partition and install OS again.
You can find how to enable secure diagnostics mode in below link.
LaszloFolgerts
I don't know the firmware anymore because I've been using the NAS like this for a few months now and haven't gotten around to fixing it sooner. I know I was going back and forth between firmware versions because I couldn't get qbittorrent working anymore.
I've also tried OS reinstall but I still can't reach the web GUI. It asks for a password and then nothing.
If I have to do a full factory reset, would it be possible to take one disk out (since in RAID 1 it's a mirror), do a factory reset, insert that disk again and then sync the formatted disk to the full disk so they're mirrored again?
Thanks
Sep 19, 2018Guru - Experienced User
RAIDar should be able to tell you the firmware. https://kb.netgear.com/20684/ReadyNAS-Downloads
No, that won't work. The NAS will sync the full disk to the empty one, and the RAID array will end up empty.
- LaszloFolgertsSep 19, 2018Aspirant
Raidar is telling me firmware version 6.6.1
- StephenBSep 19, 2018Guru - Experienced User
SInce you have access to the files, the first step is to back them up. They are at risk.
Does https://nas-ip-address/fwbroker respond?
What other apps were installed on the NAS?
is ssh enabled?
- evan2Sep 19, 2018NETGEAR Expert
