davidfregoli
Nov 26, 2014Aspirant
RN102, Mix Raid 0 and Raid 1?
Hi guys, just got an RN102, I'm gonna fill it with 2xWDRED2TB, is it possible to have this configuration? 2x800GB (1.6TB) Raid 1 iSCSI LUN for backing up my linux server and storing its bigger files...
davidfregoli
StephenB wrote: Note you could set up one iscsi LUN on each jbod disk, and run two backups (perhaps alternating between them). That's similar to RAID-1 protection.
The main issue with jbod is that you need to manually balance the storage between the two disks. That's easiest if you set things up with more/smaller shares.
This is probably what I'll end up doing, 2xJBOD, one NFS mount per drive and rsync one to the other after every backup. thanks guys
- alexjmAug 12, 2015Aspirant
I recently purchased a new NAS (3x4TB with raid 1) and looking to refurbish my old readynas nv+ with 2x2tb as a remote backup. I dont care for redundancy on the remote unit and wish to maximize the available terabyte. Thus, I tried to factory reset the remote unit and set it to flex-raid - raid zero.
I have gone through the process several times now and each time I end up with raid one and capacity of 2tb. Please help. Why wouldn't the raid zero setting with 2x2tb stick for me?
- StephenBAug 12, 2015Guru - Experienced User
What firmware are you running on the NAS?
Did you try deleting the RAID-1 volume and recreating the one you want?
FWIW, I recommend jbod (two RAID-0 volumes) - otherwise a failure to either drive destroys all your data.
- alexjmAug 15, 2015Aspirant
I understand the jbod advantage of having separate volumes. But the thing is that I dont really need redundancy with the remote nas. What I really need is to maximize capacity the 2x2tb. I have a single volume with raid 1 at the local nas and would prefer a single volume setup at the remote unit too for ease of remote back-up. It would be taxing to choose between the two remote volumes to do back-up.
Regarding your suggestion of deleting the raid-1 volume, do you suggest that i choose the "erase volume" before i select the raid-o after the factory reset action.Following is what I have been doing...I had both discs in, did the factory reset. I would think the action automatically erases both discs. I then get the prompt from raidar to select flex-raid. I selected flex-raid and raid-zero. But once the nas stabilizes out, I keep getting raid one instead with a total disc capacity of 2tb.Currently I am running firmware RAIDiator 4.1.14 [1.00a043] with the remote nas.Alex
