WelshCJ
Feb 10, 2015Aspirant
RN102: No Frontview access after Uninstall of Owncloud
Evening All, I just bought the RN102, and everything was going well with it, I decided to install a few of the applications which included OwnCloud. After a bit of a play I decided it was not wh...
Apr 11, 2015Guru - Experienced User
There is a way if you have a scratch disk, but it is a bit tedious.
m.frank wrote: ...By the way, how do I install a update there solves the problem when I can't access the front view?
You can
(a) power down the NAS. Remove all drives (labeling by slot). Install the scratch disk, and power up.
(b) The NAS will install a clean copy of 6.2.2 with a working web UI. When it completes, download 6.2.3 from this forum and install it.
(c) Then power down the NAS again and reboot.
(d) The NAS will update the OS from 6.2.2 to 6.2.3 on the original disks. That will restore the UI and prevent the problem from happening again.
