JabbaTheCat
Jun 03, 2016Guide
RN102 stuck after booting
My RN102 won't complete its reboot, sits there(+1hr at time of writing) with top light flashing at a constant rate and the two disk lights are constantly on.
Ran fine constantly for the last few months, can't remember last reboot as runs 24/7, but started getting interupted streams to the Squeezebox, eleminated cable and wireless possible cause of problem so went for the NAS reboot as last resort ;o((
Can I pull the power and turn it back on without a problem?
Pulled the plug and the old girl booted up properly, panic over...
- JennCNETGEAR Employee Retired
Hello JabbaTheCat,
Sorry for responding late. I am glad it works now.
Probably you might want to check too if there are any errors with the disks.
See the articles below:
ATA errors increasing on disk(s) in ReadyNAS
ReadyNAS: Reallocated sector errors increasing on disk(s)
Hello JabbaTheCat,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
