Campingplanner
Feb 04, 2017Aspirant
RN102 stuck at booting
After i preformed a Firmware update my NAS did not become visible in the network. After a while rebooted it, no result. Tried to reinstall os trough boot option, no result. Tried to boot from usb, ...
- Feb 13, 2017
After manually applying a one-off update that would have been done if the workaround had been used the system was able to boot up on 6.6.1.
mdgm-ntgr
Feb 04, 2017NETGEAR Employee Retired
Which firmware did you update from/to ?
- CampingplannerFeb 04, 2017Aspirant
6.2.2
to 6.6.1
- mdgm-ntgrFeb 04, 2017NETGEAR Employee Retired
I guess you didn't use this workaround?
