Campingplanner
Feb 04, 2017Aspirant
RN102 stuck at booting
After i preformed a Firmware update my NAS did not become visible in the network. After a while rebooted it, no result. Tried to reinstall os trough boot option, no result. Tried to boot from usb, ...
- Feb 13, 2017
After manually applying a one-off update that would have been done if the workaround had been used the system was able to boot up on 6.6.1.
Campingplanner
Feb 05, 2017Aspirant
Well... this is the first time i see this one... so, no. As it is now, i can not reach or find the nas in my network so this is not a solution anymore i think
- mdgm-ntgrFeb 05, 2017NETGEAR Employee Retired
Sent you a PM
- mdgm-ntgrFeb 13, 2017NETGEAR Employee Retired
