tec-man
Dec 07, 2015Guide
RN102 will not upgrage firmware
I have a 102 running 6.2.5. I had tried (multiple times and methods) to upgrade to 6.4 without luck. After the reboot it is back to 6.2.5 with no errors in the log file. I also tried installing th...
- Apr 26, 2016
I got my PM from a Netgear Tech/Engineer. After a few back and forths, he remoted into my ReadyNAS and was able to force an upgrade.
Great support solving the problem. Hopefully he will get a hold of you and do same.
Paul
BrianL2
Dec 07, 2015NETGEAR Employee Retired
Hi tec-man,
Welcome to the community!
Are you doing the automatic or manual Firmware update? Perhaps use a different computer or web browsers.
Kind regards,
BrianL
NETGEAR Community Team
- mdgm-ntgrDec 07, 2015NETGEAR Employee Retired
If that does not resolve it, have you checked the contents of initrd.log?
Does it show that the update failed?
- tec-manDec 08, 2015Guide
I have tried both manual and auto updating. Also the log shows rebooting and background task starting. No errors of any type.
paul
- AlexPeDec 08, 2015NETGEAR Expert
Hi Tec-man,
It is very likely that you are experiencing checksum issue that is resolved in 6.4.0+. To get you on the latest firmware version we will need to look into doing this workaround here ReadyNAS OS 6: RN100/RN2120 cannot update due to invalid checksum
With out seeing your logs I would assume this is the problem. If you download your logs and look at the initrd.log file it should confirm this issue.
Let me know if this helps,
AlexPe
