tec-man
Dec 07, 2015Guide
RN102 will not upgrage firmware
I have a 102 running 6.2.5. I had tried (multiple times and methods) to upgrade to 6.4 without luck. After the reboot it is back to 6.2.5 with no errors in the log file. I also tried installing th...
- Apr 26, 2016
I got my PM from a Netgear Tech/Engineer. After a few back and forths, he remoted into my ReadyNAS and was able to force an upgrade.
Great support solving the problem. Hopefully he will get a hold of you and do same.
Paul
LorenzoG9
Apr 26, 2016Aspirant
Hello to everybody,
I have the same problem of Tec-man, when i try to instal complete-flash-update_1.0_armel.deb, a message told me that it's impossible. BrianL, please, can you send me a Pm with solutions?
tec-man
Apr 26, 2016Guide
Paul
- BrianL2Apr 26, 2016NETGEAR Employee Retired
Hi tec-man,
We appreciate hearing your feedback and for letting us know that we're able to help you resolve your issue. We encourage you to mark the this read resolved by clicking the Accepted as Solution” button in one of the responses that you received.Kind regards,BrianL
NETGEAR Community Team - LorenzoG9Apr 29, 2016Aspirant
Hello,
please someone can help me? I can't upgrade the firmware of my RN102, i try to follow the guide with installation of file .db like apps, but without success. A massage told me that is impossible.
Thanks in advance
Lorenzo - LorenzoG9May 02, 2016Aspirant
Hi JennC,
many thanks for reporting of the article, following him I was able to update firmware.
Best regards
Lorenzo - BrianL2May 02, 2016NETGEAR Employee Retired
Hi LorenzoG9,
We appreciate your feedback and for letting us know that the information we provided has helped resolve your issue. We hope that you will continue to be an active member of the community.
Kind regards,
BrianL
