JanvdBrink
Nov 10, 2020Tutor
RN10200 – .mars malware infection: please help with suggestions…
Hi, yesterday i noticed that last Saturday the .mars malware had infected the data on my NAS. Unfortunately also the back-up files. I back-up to offline usb in the weekends :-( All my data was encryp...
JanvdBrink
Nov 10, 2020Tutor
Thanks Stephen,
Mail is coming from the Ubuntu workstation and just backupped to the NAS. I will check the mail again, but till now I did not find any infected files.
I might scan my Ipad since in the past I used to copy files from it to the NAS as well.
I don't think I copied or moved any files from my (work) Windowslaptop to the NAS, but a check would do no harm.
I'll post the results.
Jan
Nov 10, 2020Guru - Experienced User
If the windows laptop has write access to the NAS then it might be the source of the infection (even though you didn't move files).
