abmcssupport
Dec 29, 2016Aspirant
RN10222D Power Light (blue) Slowly Flashing
I was working on the web console of my NAS and it reported the lastest firmware was available, once I had finished my changes I downloaded and start the upgrade, that was my biggest mistake! Knowing...
- Jan 12, 2017
Was not able to do a USB or boot menu restore, both options failed and telephone support was not able to resolve issue.
Unit was RMA'ed under warranty .
mdgm-ntgr
Dec 29, 2016NETGEAR Employee Retired
Which firmware did you update from? It sounds like you may not have followed the recommended firmware update path, though the update presented by the GUI would be the recommended one. It wou only be if you were doing a manual update that you might not follow the recommended update path.
Perhaps try USB Boot Recovery with 6.6.1 Beta
mdgm-ntgr
Jan 11, 2017NETGEAR Employee Retired
Any update?
- abmcssupportJan 12, 2017Aspirant
- mdgm-ntgrJan 12, 2017NETGEAR Employee Retired
Thanks for the update. I would suggest putting a scratch disk (must not be from your array) in the replacement, updating to 6.2.5 if running older firmware than 6.2.1 and then using this workaround to update to 6.6.1: ReadyNAS OS 6: RN100/RN2120 cannot update due to invalid checksum
If the replacement is already running 6.4.0 (or later) you can update the replacement directly to 6.6.1.
Then power down, remove the scratch disk and move your disks to the replacement unit.- abmcssupportJan 12, 2017Aspirant
The replacement has arrived and have installed with disks as before.
unit booted and all data was available still.
Have been able to update via web console to latest version and unit is working OK now.
thanks for the suggestions and help.
