K3N8
Sep 03, 2014Aspirant
RN104 - Installation
Hi everybody, I have just installed three 3TB disks and the RN104 is currently resyncing data at 1,18%. I've setup the RN104 through ReadyCloud and everything looks allright. I have 5,23 TB availab...
Sep 04, 2014Guru - Experienced User
If you don't need a secure connection, you might try NFS instead of rsync - it should be faster. You can then re-do with rsync incremental (editing the backup job if you use frontview backup) if you like.
