wydra
May 04, 2015Aspirant
RN104 - keeps freezing after 6.2.3 & 6.2.4 updates #25088243
Hi, I seem to be having the same issue a lot of people are having. I was originally running 6.2.2 and everything was working perfectly. I was prompted on the admin page that a new firmware 6.2.3 w...
Poorty
Aug 17, 2015Aspirant
Hello,
I am having the exact same issues. I have been running the readyNAS now for about 4 weeks. It keeps freezing and hanging. The only way to fix is to do a hard reset by pulling the power. Should I also downgrade to 6.2.2? Can you please advise how I am able to fix this issue?
- StephenBAug 17, 2015Guru - Experienced User
Current firmware is 6.2.5, and the release notes include
- Adjusted CPU and memory timing to improve system stability on RN10x models.
So I'd try that before downgrading.
What apps are you running?
- Jan 17, 2024Retired_Member
