wydra
May 04, 2015Aspirant
RN104 - keeps freezing after 6.2.3 & 6.2.4 updates #25088243
Hi, I seem to be having the same issue a lot of people are having. I was originally running 6.2.2 and everything was working perfectly. I was prompted on the admin page that a new firmware 6.2.3 w...
Poorty
Aug 17, 2015Aspirant
Hi Stephen,
I am running 6.2.5 and have been since it was release late last month.
I'm only running plex (newest version from netgear App Store) and I just removed the default antivirus software to see if that was causing it. So basically just running plex.
Josh
Josh
- StephenBAug 17, 2015Guru - Experienced User
A few months ago I was seeing odd lockups when plex was refreshing metadata. The system became unresponsive to ping, and I needed to pull the plug. I haven't seen that lately, though I haven't rescanned all the metadata lately either.
You might try manually rescanning, and see if that provokes the problem for you. Also, perhaps install the newest version of plex (it should be here: http://apps.readynas.com/pages/?page_id=9)
- Jan 17, 2024Retired_Member
