wydra
May 04, 2015Aspirant
RN104 - keeps freezing after 6.2.3 & 6.2.4 updates #25088243
Hi, I seem to be having the same issue a lot of people are having. I was originally running 6.2.2 and everything was working perfectly. I was prompted on the admin page that a new firmware 6.2.3 w...
Poorty
Sep 26, 2015Aspirant
Hey phillipGood,
I have had no issue what so ever since upgrading the firmware. I also upgraded to the newest version of PLEX (the only app I am running) on the NAS. I also have the unit set to power down every night at 1am and power back up at 4pm with the 6.2.5 firmware (as I thought this may have been causing the issues before) and it has no issues when powering back on since upgrading.
Suggest looking nice at your firmware first! It fixed all the issues for me!
Cheers,
Josh
Cheers,
Josh
philipGood
Sep 27, 2015Aspirant
Hi Josh, I am on 6.2.5 and this is where the problems started. I used to be on 6.2.2 and avoided 6.2.3 and 6.2.4. I do not have PLEX or AntiVirus running on mine (uninstalled after your post) but I do have SickBeard and SABNZB running. However, SAB and SickBeard do not really get accessed all that much and these crashes seem to be happening when either SnapShots were being takes (since disabled) or when I am accessing the drives. I'm starting to wonder if 6.2.5 ws installed improperly, or perhaps didn't flash correctly.
Just to make sure you are on the same page, you also had the issue where the buttons on the unit were unresponsive and you could not access neither the drives nor the ReadyNas GUI?
Cheers,
Phil
- Jan 17, 2024Retired_Member
