wydra
May 04, 2015Aspirant
RN104 - keeps freezing after 6.2.3 & 6.2.4 updates #25088243
Hi, I seem to be having the same issue a lot of people are having. I was originally running 6.2.2 and everything was working perfectly. I was prompted on the admin page that a new firmware 6.2.3 w...
philipGood
Sep 27, 2015Aspirant
Hi Josh, I am on 6.2.5 and this is where the problems started. I used to be on 6.2.2 and avoided 6.2.3 and 6.2.4. I do not have PLEX or AntiVirus running on mine (uninstalled after your post) but I do have SickBeard and SABNZB running. However, SAB and SickBeard do not really get accessed all that much and these crashes seem to be happening when either SnapShots were being takes (since disabled) or when I am accessing the drives. I'm starting to wonder if 6.2.5 ws installed improperly, or perhaps didn't flash correctly.
Just to make sure you are on the same page, you also had the issue where the buttons on the unit were unresponsive and you could not access neither the drives nor the ReadyNas GUI?
Cheers,
Phil
Sep 27, 2015Guru - Experienced User
fwiw, 6.2.5 is working fine on my RN102.
You could try overinstalling the firmware from the web ui.
- Jan 17, 2024Retired_Member
