wydra
May 04, 2015Aspirant
RN104 - keeps freezing after 6.2.3 & 6.2.4 updates #25088243
Hi, I seem to be having the same issue a lot of people are having. I was originally running 6.2.2 and everything was working perfectly. I was prompted on the admin page that a new firmware 6.2.3 w...
Poorty
Sep 27, 2015Aspirant
Phil,
Yes correct exact same issues the unit would be unresponsive and the power button on the front would not work. The only way to fix was to physically remove power source to reboot. Suggest trying to remove all apps - just to rule them out and set snapshots to weekly instead of daily. Also do you have the NAS mapped as a network drive in Windows? I found that this was causing me issues when to so I can still access from my Windows machine but don't have it mapped as a network drive.
Cheers,
Josh
Cheers,
Josh
- Jan 17, 2024Retired_Member
