K3N8's avatar
K3N8
RN104 - New setup after firmware crash
Hi,   I've had a crash after upgrading the firmware to 6.4.0 on my RN104. It was stuck on booting. The guys from Netgear were very helpful, but to no avail. I had to do a factory-default on a new 3...
  • StephenB's avatar
    Oct 21, 2015
    Don't format the drives ahead of time, it just gets in the way.  What you can do is unformat them. In Windows you do this with the disk manager - right-clicking on every volume (which amount to a partition) and deleting it.  That allows the NAS to directly add them to the array w/o your needing to confirm.
    K3N8 wrote:
    What is the best thing to do:
    1. Put in the disks on at a time;
    2. Add all the disks at the same time when the RN104 is down.
    There is an option 3 of course - add them all at once while the NAS is running.
    I'd add them one at a time with the NAS running.  The NAS doesn't really care (it will add them one at a time to the array no matter what you do).  However, if something goes wrong, it is easier to diagnose if you add one at a time and wait for the resync to complete.
ProSupport for Business
