elfworks
Oct 07, 2015Tutor
RN104 - Stuck "Booting..." after automatic 6.4.0 upgrade.
Went to Boot Mode. Tried OS Reinstall. Tried Factory Reset. Pulled out the drives. Always end up stuck on 'Booting..." Please give us instructions on how to do a USB Recovery. Please don'...
- Oct 07, 2015
Hi,
If you've bricked your chassis during upgrade, you can do the USB boot recovery tool from this KB article:
http://kb.netgear.com/app/answers/detail/a_id/29952
Review our KB for the steps.
Put the ReadyNAS 6.4.0 firmware into the marvell folder, insert a USB less than 8 GB and format it fat32, then open the tool and select the drive letter, click format again, then drill down to the RN100 series and execute the tool with 6.4.0 selected.Then during boot of your ReadyNAS, hold the backup button for around 10 seconds. Then the unit will blink repeatedly for some time and when it was successful, it will just shut off. Then remove the USB and try to boot normally again.The RN104 will tell you on the LCD that it is in USB recovery mode.I'll update the tool later for the new ReadyNAS units.I just updated the tool to include RN2xx series devices. It might take time to replicate on our CDN though.
shiek403
Oct 10, 2015Aspirant
I have now done the reflash 3 times, and not one has worked.
mine looked like it locked up mid balance, when I came in thie morning, the screen just showed "balance 28%" and didn't move for 30 min (nor did the screen turn off)
did a flash drive fix on 6.4, no go, did one for 6.2.4 and it actually booted, then almost immediately crashed.
am now doing the boot menu OS reinstall, and hoping that will work.
but what other options do I have, I DO NOT want to wipe my disk... I have a lot of stuff on here that I would rather not lose...
