RPG_228
Aug 26, 2015Aspirant
RN104 adding third drive takes very long
Hello everyone, I've got a readynas 104 with 2 x 2TB drives (XRAID). They are 95% full of data so i added a third 2 TB drive. Since i added the third drive the drive i can't view the admin pa...
- Aug 27, 2015
Thanks for the logs.
Your data volume is pretty much 100% full.This is not good.
We recommend keeping volume usage around the 80-85% mark.Do you have a backup? You should backup your data if you have not already as the next step.
It looks like your new disk has been added to the data volume array, but not to the OS or swap arrays. Expansion has not occurred.
You could try rebooting the NAS via RAIDar and see what happens.
Aug 26, 2015Guru - Experienced User
What status is RAIDar giving you?
If you don't have a backup, it would be a good idea to make one.
