mads0100
Jan 03, 2015Guide
RN104 and NIC settings
Hello, I keep trying to change my NIC settings. I try to change the MTU settings (I've heard higher is better?) and it results in the GUI failing. Any ideas?
vandermerwe
Jan 03, 2015Master
Well,it's probably not the GUI failing, it's your network connection failing. You need to set other devices to the same mtu setting (PC NIC card, switch and anything else on the route between nas and PC) . Have you done this?
Changing this generally causes more problems than it solves, for many users.
What are you doing that needs higher performance?
