mads0100
Jan 03, 2015Guide
RN104 and NIC settings
Hello, I keep trying to change my NIC settings. I try to change the MTU settings (I've heard higher is better?) and it results in the GUI failing. Any ideas?
vandermerwe
Jan 03, 2015Master
PC to PC via a switch? Is the switch a managed switch or is it compatible with the frame size you want?.
What mtu size is set on the PCs?
