mads0100
Jan 03, 2015Guide
RN104 and NIC settings
Hello, I keep trying to change my NIC settings. I try to change the MTU settings (I've heard higher is better?) and it results in the GUI failing. Any ideas?
vandermerwe
Jan 03, 2015Master
Do you have a different switch to try?
What make/model is the switch?
Are the PC, switch and nas all directly connected by at least cat 5e cables?
No other devices in route from nas to PC?
There is no wifi involved is there?
How did you decide to use 5000?
Can you ping the nas from the PC?
ping NASIPADDRESS -f -l 5000. Edit - not quite correct, see StephenB's advice in next post.
