mads0100
Jan 03, 2015Guide
RN104 and NIC settings
Hello, I keep trying to change my NIC settings. I try to change the MTU settings (I've heard higher is better?) and it results in the GUI failing. Any ideas?
vandermerwe
Jan 03, 2015Master
Well it depends what you're doing over the LAN.
I think that for certain applications, if you have the hardware to get jumbo frames to work, then it is beneficial.
