schwizer
Aug 13, 2018Aspirant
RN104 Automatic login credentials possible?
I frequenty use an Edge browser in W10 (don't hate me) to login to the admin page of the readynas and it asks me for login credentials each time even though i check "save login". Any way to make it ...
- Aug 21, 2018
So i was not able to get that clear command to work but i did go back into the NAS and added another user with my windows login credentials and it has now started working. Meaning i am logged into the admin page automatically without a popup asking for username. Seems like i just didn't wait long enough the first time for the windows credentials to update.
Thanks for the help
Schwizer
Retired_Member
Aug 13, 2018Hi schwizer, nobody should hate you because of you utilizing a specific browser. As long as Edge suites your needs and you are fine with its way of dealing with your data, you have an acceptable solution.
However, in your case Edge seems to not being capable of keeping in mind the credentials for your nas. And that makes this question to my opinion a clear Windows/Edge question about how credentials are managed on your pc.
Why not looking into the (advanced) settings of Edge to find out how it currently treats credentials. It could very well be, that for security reasons you are wiping out certain information after each browser session. Of course, that would explain the "forgotten" credentials, though.
Good luck with fixing and kind regards.
